It is currently Sun Jul 06, 2025 6:52 pm
PostPosted: Sat Sep 16, 2006 2:38 am
Recommendations for a chatter free countersink?
I'm buying blade stiffeners from Lee Valley and want to buy something else..
I've had poor results with some contersinks. What works well and at what speed, for irregular grain, esp for BRIDGES?
I've seen ball mills, unibit step drills, single and multi flute countersinks.
I need smooth! But do I have to clamp every time I countersink?Terry Stowell38976.5212847222
PostPosted: Sat Sep 16, 2006 3:11 am
Terry,
What are the dimensions of your holes, both pilot and countersinnk? They make comination drills.
PostPosted: Sat Sep 16, 2006 6:01 am
    I have found the single lip countersinks work the best. The multifaced cutting provides too much cutting surface which overcomes the rigidity of the drill press and chuck. The single-lip also tends to burnish the chamfer to some degree.
    In wood, I generally use a relatively high speed and light feed. This seems to prevent tearout, relatively well.
Billy DeanBilly T38976.6298726852
PostPosted: Sat Sep 16, 2006 6:13 am
First name: Tracy
Last Name: Leveque
State: CO
Terry,
Get this ONE in a 3/8" size. It was recommended to me by a local luthier/repair guy. I have tested it, and it is totally chatter free with a hand drill!
PostPosted: Sat Sep 16, 2006 8:04 am
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
Zip/Postal Code: 98506
Yup! What Tracy said. They work GREAT!
-Mark
Pullman, WA
trippguitars.com
OR
Find me on Facebook
PostPosted: Sat Sep 16, 2006 1:09 pm
Thanks. Just what I thought, just by the nature of the design, I thought it would work.
PostPosted: Sat Sep 16, 2006 1:11 pm
Yeah, those zero-flute sinks work really well. However, don't waste your time with the cheap imports. They'll just disappoint you by not being sharpened appropriately to begin with, and by dulling too quickly. Don't panic, though. Even the good ones in the sizes we use shouldn't cost more than ten bucks.
PostPosted: Sat Sep 16, 2006 1:34 pm
Yeah, I think I had one of the cheapies that dissappointed. I'm ordering some blade stiffeners from Lee Valley, and I'll get a couple other goodies too!
Thanks guys!
PostPosted: Sat Sep 16, 2006 2:26 pm
Thanks Tracy. I have been trying to remember where I saw them.
PostPosted: Sat Sep 16, 2006 3:24 pm
For bridges, I use a cone-shaped stone in a Dremel. No chance of tearout, and produces a lovely countersink. And the aroma of BRW smoke... ah....
I use the same cone(this Dremel is set aside with this stone in it all the time, I use it so much) for also esing the edges of the tuner holes, for the bushings, for the end pin, and for the bolt holes in the body. Anything that needs a slight chamfer....
PostPosted: Sat Sep 16, 2006 3:48 pm
Mario,
How do keep the stone from loading up?
PostPosted: Sat Sep 16, 2006 3:52 pm
Shane, I use coarse, medium and fine.
Typically buy my my fret fret wire from LMI or Allied as I like it coiled. Will you be selling it staight or coiled? Jim_W38977.037349537
PostPosted: Sun Sep 17, 2006 3:03 am
It doesn't load up. At least, not enough to affect it.
PostPosted: Sun Sep 17, 2006 12:35 pm
[QUOTE=ToddStock] Woodcraft used to carry Weldon[/QUOTE]
Reid Tool carries Weldon.
www.reidtool.com
Look under "cutting tools" for countersinks.
PostPosted: Mon Sep 18, 2006 1:41 am
[QUOTE=Mario] For bridges, I use a cone-shaped stone in a Dremel. No chance of tearout, and produces a lovely countersink. And the aroma of BRW smoke... ah....
I use the same cone(this Dremel is set aside with this stone in it all the time, I use it so much) for also esing the edges of the tuner holes, for the bushings, for the end pin, and for the bolt holes in the body. Anything that needs a slight chamfer....[/QUOTE]
Thanks for the tip, Mario. Great idea.
Todd Rose
Ithaca, NY
